I need a higher case and don't see any options for more than 1U sides.
Where do I download the rest of the side profiles?
I only see 1U sides in the drop down menue
Re: I only see 1U sides in the drop down menue
In the case of extruded aluminum, we only have 1U sides. For taller enclosures a normal sheet metal enclosure is the only thing we can offer at this time (U-Shape, L-Shape, etc).
The 1U Extruded enclosure is a kind of experiment through which we are trying to judge whether there is demand for these sorts of things. I will pass on you are interested in a taller extruded enclosure.
There is definitely a need for higher cases.
The ability to combine elements from different templates as well and most of all,
the ability to ADD faces on any template, or design from scratch!
Good work.
Good work.
