Case Dimensions
roberth909
Case Dimensions
Post by roberth909 »
Are the dimensions of the case in the designer the outside or the inside of the case? I have circuit board mounted controls and I need to get the height of the case correct so that it will fit in the case properly.
Thanks!
Re: Case Dimensions
The dimensions are the outside of the chassis - this is because that is the easiest to measure accurately. However, if you are making an L-Shape, I just found a bug and the dimensions are not quite correct. Let me know and I'll speed up the fixing of that one.
