I'm using protocase designer 4.2.0, and was experimenting with the powder coat color for the top of my enclosure using the "Edit Enclosure Properties" menu. After selecting a few colors, the TopColor option disappeared, and I can no longer change to the top color of my enclosure (see the attached picture). Is there a workaround to change to the top color? Do I have any options, or do I just need to restart from scratch?
Thanks.
can't change top color from "Edit Enclosure Properties" menu
- NoTopColorDropDown.png (201.23 KiB) Viewed 16038 times
Re: can't change top color from "Edit Enclosure Properties" menu
I believe you will find this fixed as soon as the new version is out. Or if you like, you can download a beta from
http://www.protocasedesigner.com/RELEAS ... -4.2.2.exe
Great. I'll try the beta version of 4.2.2.
Another work around I figured out is to manually edit the .pda file using a text editor. The .pda file appears to just be an .xml file. If I manually change the TopColor entry to the default value as shown below, the top color is restored to the default, and the menu option returns.
<Parameter default="Use Default" description="the color of the box"
name="TopColor" template="true" units="MetalColor"/>
While this is probably not a "recommended" solution, it may be a helpful work around for computer savvy users.
I correlated the problem to using colors that have hyphens in their name. I'm guessing the xml parser doesn't like parameters with hyphens.
This bug has been fixed in the latest beta:
http://www.protocasedesigner.com/RELEAS ... c-Jan5.exe
you will have to allow it to update your template to the latest version and then the Top Color should become available again.
