Questions about designing custom enclosures using Protocase Designer
willsmith
Post by willsmith »
Hello everyone,
I'm currently trying to design a custom enclosure for an electronic device using Protocase Designer software. This is my first time using this tool, so I'd like to ask for some advice from those who have ordered or had their products manufactured by Protocase.
Specifically, I want to know:
When designing an enclosure, are there any important standards or considerations to avoid errors when sending the production file?
Is there a significant discrepancy between the design in the software and the actual product?
If I want laser engraving or color printing on the surface, what graphic file format should I prepare for the best quality?
If anyone has practical experience, I would greatly appreciate it if you could share it so I can finalize my design before placing an order.
Thank you!
“The only way to do great work is to love what you do.” — Steve Jobs space waves
northwestutilized
Re: Questions about designing custom enclosures using Protocase Designer
Post by northwestutilized »
It might help to share a screenshot or the design file so others can see exactly what’s going on. Small things like bend settings or flange dimensions can sometimes cause unexpected issues in Protocase Designer.
andreagibbs
Post by andreagibbs »
Great questions! From experience, it’s important to double-check tolerances, mounting hole alignment, and internal clearances before submitting your file — especially if you’re fitting PCBs or connectors. The software is generally very accurate to the final product, but always review bend allowances and material thickness carefully.
For laser engraving or color printing, vector files like .AI, .EPS, or .SVG usually give the best quality results.
Good luck with your first enclosure!
Yunre
Post by Yunre »
This will catch issues that might make your design unbuildable before you upload it. The software flags errors and warnings with explanations so you can fix things early.
masdiamo
Post by masdiamo »
Hi! I’ve used Protocase Designer for a few projects. A few tips from my experience:
Standards & considerations: Always double-check your wall thickness, bend radii, and hole clearances. Protocase has recommended minimums (like 0.8 mm for bends) — following those prevents errors during fabrication.
Design vs. reality: Generally very close, but sometimes bends and tab fits can feel slightly tighter or looser than on-screen. Ordering a prototype or single unit first can save headaches.
Engraving & printing: For laser engraving, vector files (AI, EPS, or PDF with vector paths) work best. For color printing, high-res PNG or PDF at 300 dpi usually gives sharp results.
Hope that helps! Prototyping first is key.
