Suppose I specify aluminium for front panel on whatever U rackmount enclosure, without handles. Apart from the standard 5 studs that fixes with the rest of the enclosure, suppose I want to add also some custom studs.
If I specify anodizing process, how gets masked all those studs on the anodized surface on front ?
Perhaps the default standard 5 studs have to be just visible plain screws on front surface ? I am thinking about the required solidity when the rackmount weight happen to be held in the aluminium front panel only.
how gets masked a stud on anodized aluminium front panel ?
longingpolitenes
Re: how gets masked a stud on anodized aluminium front panel ?
Anodizing coats all exposed aluminium. Studs or threaded features made of aluminium will also be anodized unless you explicitly ask for masking or thread chasing after anodizing. Steel studs or screws are normally installed after anodizing and remain uncoated.secarica wrote: ↑Mon Feb 20, 2023 7:03 pmSuppose I specify aluminium for front panel on whatever U rackmount enclosure, without handles. Apart from the standard 5 studs that fixes with the rest of the enclosure, suppose I want to add also some custom studs.
Rack mounting screws on the front are normally visible; that is standard practice.
Do not rely on an aluminium front panel to carry the unit’s weight. The load should be supported by rear rails or internal chassis supports, not the front panel alone.
On anodized aluminum panels, studs are typically installed after anodizing, or they’re masked so the anodize doesn’t build up on the contact areas. For rackmount panels, the standard front studs are usually visible hardware and provide sufficient strength when properly specified. If you’re concerned about load-bearing, it’s best to note this in the design notes so the manufacturer can choose the appropriate stud type and installation method.
Frank Craig
geometry dash
geometry dash
routinefee
In practice, the studs or threaded inserts are usually installed after anodizing, or they’re masked/plugged during the anodizing process. Threaded holes are commonly protected with silicone or plastic plugs so the threads stay conductive and dimensionally correct.
For front panels that need to carry load, I’ve mostly seen PEM studs/inserts pressed in after anodizing, or the load transferred to the chassis rather than relying on the anodized front panel alone. Using visible screws for the main mounting points is also pretty common and avoids strength issues.
If the panel is structural, I’d be cautious about relying only on aluminum thickness plus anodizing—mechanical fastening into the frame usually makes more sense.
I once needed to touch up a scratch on my vintage camera body, which had a similar anodized finish. Ended up with a bigger mess trying to mask it with regular tape. Slice Master recommended specialty tape to avoid adhesive residue.
I’m thankful for the information being discussed here. Companies that aim to keep their products competitive should treat feedback like this as an opportunity to improve dependable items like nitrile gloves.
