Question about brackets
Red Squirrel
Post by Red Squirrel »
I'm working on designing a 2U case and I'm trying to make some HDD slots and using the U bracket to do it, but it seems there are rather specific size constraints on brackets, so it's not letting me make it the size that I need for a hard drive to slide in it.
Is there an alternate way of doing something like this? Like if I need sheet metal bent a specific way and size, and be an assembly that can be screwed in what is best way to approach that?
Re: Question about brackets
Are you able to provide sketch of the bracket? I might be able to suggest something.
In PD you can add a sub-assembly of a bracket and when attaching it to a face you specify the method of attachment(fasteners, welding, other). https://www.protocasedesigner.com/wiki/ ... ubassembly
Most of our manufacturing constraints are built in PD so there might not be a workaround but you can reach out to our Engineering Design Services for more advanced help. https://www.protocase.com/contact/
Resources on the software: https://www.protocasedesigner.com/resources/
Best Regards,
Red Squirrel
Here's a crude sketch but it would not let me make it those dimensions. Essentially this would be a part that lets you screw 6 hard drives to it and then it would screw into the case, or maybe slide into a rail from the front. Still experimenting at this point.
rapid3dtechnologies
Post by rapid3dtechnologies »
Rapid3D has become one of Chennai's leading providers of 3D printing and scanning services, offering high-quality services that satisfy clients. Our skilled professionals will assist clients in selecting the appropriate material, transport the product, and ensure prompt delivery. We print using modern equipment, and each year we distinguish ourselves by releasing a range of samples. Get your best 3D design printing service in Chennai at a reasonable cost
visit now for free quote https://rapid3d.co.in/3d-printing-chennai/
