reversing the mouse wheel direction for zoom ?
Is there an option to reverse the zoom direction when using the mouse wheel ? Currently it is counterintuitive and in reverse than usual in most other programs (at least on Windows). I zoom in the wrong direction mostly at each wheel rotation, only to realize milliseconds later the fault and rotate then back almost double than needed.
Re: reversing the mouse wheel direction for zoom ?
Hi Secarica,
See if you can turn on/off the zoom to mouse setting and if that helps. It doesn't change the zoom direction(prefrences->editor settings) by the looks of it but might help a little. We'll have to add setting to reverse the zoom direction.
Well, I will wait for that option to materialize
It's not critical, don't get me wrong.
'Zoom to mouse', while being an useful feature, has nothing to do with the mouse wheel direction and appears to be an option for 3D view only (main view), the editor is working that way already (or so it seems to me).
See if the program itself has an “Invert zoom direction” checkbox. If it doesn’t, use X-Mouse Button Control (free) to create a profile just for that program, and swap Wheel Up/Wheel Down actions.best sex dollssecarica wrote: ↑Sun Apr 21, 2024 5:38 amIs there an option to reverse the zoom direction when using the mouse wheel ? Currently it is counterintuitive and in reverse than usual in most other programs (at least on Windows). I zoom in the wrong direction mostly at each wheel rotation, only to realize milliseconds later the fault and rotate then back almost double than needed.
tonemao85243
- Contact:
I know some people are hesitant, or even fall in love with their sex dolls, but it can also fill an emotional void.
