D-Hole Entered Properties
tegtmeyerm
Post by tegtmeyerm »
Why are D-hole cutouts specified in the property table as diameter/edge length? I can't say that I've looked at every data sheet specifying a D-hole but every one that I've run across specifies it as diameter/truncated width (ie width of the axis with the flat).
My current workaround (without having to do math) is to model the D-hole in FrontPage Designer, measure the flat, and then enter that dimension in Protocase Designer--which is tedious. Is there a technical reason for the way it is done now?
Re: D-Hole Entered Properties
Hello tegtmeyerm,
Not to my knowledge. It is a good suggestion to add for future releases. Other than doing out the math I don't really help full information.
Thanks for the feed back and I'll add this into your system to look into for future releases but I can't say when we will get to it.
