Dues to different reason, but mainly EMI/EMC I like to use the U-shape template for design a 19" rack mountable case.
How can I add the usual rack mount flange to the design?
Is it better to buy it separately?
U-shaped into 19" rack
Re: U-shaped into 19" rack
Hey Bertalan,
it is possible to add other parts into your template file. Please see the documentation here:
http://www.protocasedesigner.com/wiki/i ... ubassembly
It would be no problem to order them in separate files and specify that they should be one assembly.
thank you Colin, I will look after this way...
