Beta Bug Reports
Beta Bug Reports
When using the Protocase Designer Beta, it is likely that you will occasionally encounter bugs. If you do so, please leave a brief note here about what you were doing and whether there was any message.
Thank you
tchen
Re: Beta Bug Reports
Post by tchen »
  • When you select an incomplete path, line to draw with does not appear.[edit]fixed april 27[/edit]
  • Right clicking shapes doesn't bring up properties dialog box [edit]fixed april 26[/edit]
  • SQL error when trying to register[edit]fixed april 26[/edit]
  • When selecting shape, context toolbar doesn't display proper shape type[edit]fixed april 27[/edit]
tchen
Post by tchen »
General
  • Register and Resize use same shortcut (Alt-R)
  • View>Toggle Flat doesn't work on first try
  • File>Save and Edit>Select A Face use same shortcut (Alt-S)
  • View>View Parts and View>Reset View use same shortcut (Alt-V)
Face Editor
  • help text wraps partial words[EDIT]fixed May 2[/EDIT]
  • Grid extends beyond face
  • no right-click options[EDIT]fixed April 27[/EDIT]
  • Colour names cut-off on info panel
  • Many shortcut commands are duplicated
  • Grid>Grid Size twice in menu (one should be Snap to Grid[EDIT]fixed April 29[/EDIT]
  • Selecting object then changing type doesn't always work[EDIT]fixed April 27[/EDIT]
  • Templates
    • Bends not correct size
    • depth must be 2" >= height, not 2">height[EDIT]Fixed May 2[/EDIT]
    • exclusion zone doesn't resize when resizing enclosure
  • Face Editor
    • use diameter rather than radius for circles
    • use user units for displaying values[EDIT]Fixed May 2[/EDIT]
    • Thickness of edges not shown
  • Copy/Paste
    • shouldn't group into an assembly[EDIT]Fixed May 2[/EDIT]
[*]list version # in help->about[/list]
spell
Post by spell »
Hi. I hit the following SEGV while rotating the view of a newly created enclosure. I'm running the protocaseDesigner-beta-OSX-0505 version of 5/5/11.
Code: Select all
Process:         JavaApplicationStub [1861]
Path:            /Users/spell/Desktop/jdesignerBetaOSX rc May 5.app/Contents/MacOS/JavaApplicationStub
Identifier:      com.protocase.viewer.JDesigner
Version:         ??? (100.0)
Code Type:       X86-64 (Native)
Parent Process:  launchd [158]
Date/Time:       2011-05-05 22:25:46.051 -0400
OS Version:      Mac OS X 10.6.7 (10J4138)
Report Version:  6
Interval Since Last Report:          20123 sec
Crashes Since Last Report:           1
Per-App Interval Since Last Report:  3376 sec
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      AD3E21FA-1FA1-46A5-978F-080E7DAA513A
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Crashed Thread:  17  Java: Finalizer
Application Specific Information:
Java information:
 Exception type: Bus Error (0xa) at pc=7fff88ff3633
 Java VM: Java HotSpot(TM) 64-Bit Server VM (19.1-b02-334 mixed mode macosx-amd64)
Current thread (10513f000):  JavaThread "Finalizer" daemon [_thread_in_native, id=239079424, stack(10e301000,10e401000)]
Stack: [10e301000,10e401000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  com.sun.opengl.impl.GLImpl.glIsList(I)Z+0
j  com.protocase.things.dispList.finalize()V+22
v  ~StubRoutines::call_stub
j  java.lang.ref.Finalizer.invokeFinalizeMethod(Ljava/lang/Object;)V+0
j  java.lang.ref.Finalizer.runFinalizer()V+45
j  java.lang.ref.Finalizer.access$100(Ljava/lang/ref/Finalizer;)V+1
j  java.lang.ref.Finalizer$FinalizerThread.run()V+11
Java Threads: ( => current thread )
  106304000 JavaThread "TimerQueue" daemon [_thread_blocked, id=591400960, stack(123301000,123401000)]
  1052a3800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=564101120, stack(1218f8000,1219f8000)]
  105258800 JavaThread "Poller SunPKCS11-Darwin" daemon [_thread_blocked, id=552054784, stack(120d7b000,120e7b000)]
  10521b000 JavaThread "Thread-4" [_thread_blocked, id=550993920, stack(120c78000,120d78000)]
  105001000 JavaThread "Thread-3" [_thread_blocked, id=549933056, stack(120b75000,120c75000)]
  1062f9000 JavaThread "DestroyJavaVM" [_thread_blocked, id=75501568, stack(104001000,104801000)]
  1060df000 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=548872192, stack(120a72000,120b72000)]
  106174800 JavaThread "AWT-Shutdown" [_thread_blocked, id=517558272, stack(11ec95000,11ed95000)]
  106231000 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=1887374496, stack(7fff5f400000,7fff5fc00000)]
  105802000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=244383744, stack(10e810000,10e910000)]
  105801800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=243322880, stack(10e70d000,10e80d000)]
  106005800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=242262016, stack(10e60a000,10e70a000)]
  106005000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=241201152, stack(10e507000,10e607000)]
  105800800 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=240140288, stack(10e404000,10e504000)]
=>10513f000 JavaThread "Finalizer" daemon [_thread_in_native, id=239079424, stack(10e301000,10e401000)]
  10513e800 JavaThread "Reference Handler" daemon [_thread_blocked, id=234876928, stack(10deff000,10dfff000)]
Other Threads:
  10513a000 VMThread [stack: 10ddfc000,10defc000] [id=233816064]
  10580b800 WatcherThread [stack: 10e913000,10ea13000] [id=245444608]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 par new generation   total 19136K, used 1333K [7f3000000, 7f44c0000, 7f44c0000)
  eden space 17024K,   2% used [7f3000000, 7f3058180, 7f40a0000)
  from space 2112K,  46% used [7f40a0000, 7f4195440, 7f42b0000)
  to   space 2112K,   0% used [7f42b0000, 7f42b0000, 7f44c0000)
 concurrent mark-sweep generation total 63872K, used 4380K [7f44c0000, 7f8320000, 7fae00000)
 concurrent-mark-sweep perm gen total 35388K, used 26812K [7fae00000, 7fd08f000, 800000000)
Virtual Machine Arguments:
JVM Args: -Xbootclasspath/a:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 8192M, Free = 3338M
Thread 0:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib             	0x00007fff8380829a mach_msg_trap + 10
1   libSystem.B.dylib             	0x00007fff8380890d mach_msg + 59
2   com.apple.CoreFoundation      	0x00007fff87558932 __CFRunLoopRun + 1698
3   com.apple.CoreFoundation      	0x00007fff87557dbf CFRunLoopRunSpecific + 575
4   com.apple.HIToolbox           	0x00007fff876dc74e RunCurrentEventLoopInMode + 333
5   com.apple.HIToolbox           	0x00007fff876dc553 ReceiveNextEventCommon + 310
6   com.apple.HIToolbox           	0x00007fff876dc40c BlockUntilNextEventMatchingListInMode + 59
7   com.apple.AppKit              	0x00007fff8535be02 _DPSNextEvent + 708
8   com.apple.AppKit              	0x00007fff8535b751 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155
9   com.apple.AppKit              	0x00007fff85321427 -[NSApplication run] + 395
10  libawt.jnilib                 	0x000000010ea551fe +[AWTStarter startAWT:] + 1495
11  libawt.jnilib                 	0x000000010ea19fca -[CPerformer perform] + 93
12  com.apple.Foundation          	0x00007fff82c7c32f __NSThreadPerformPerform + 219
13  com.apple.CoreFoundation      	0x00007fff8755a401 __CFRunLoopDoSources0 + 1361
14  com.apple.CoreFoundation      	0x00007fff875585f9 __CFRunLoopRun + 873
15  com.apple.CoreFoundation      	0x00007fff87557dbf CFRunLoopRunSpecific + 575
16  ...ple.JavaApplicationLauncher	0x00000001a34a8fa7 startupJava(LauncherArgsStruct*) + 238
17  ...ple.JavaApplicationLauncher	0x00000001a34aadda launchJavaApplicationWithJVMInfo + 1254
18  com.protocase.viewer.JDesigner	0x00000001a34a2b7c 0x1a34a2000 + 2940
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib             	0x00007fff8382112a kevent + 10
1   libSystem.B.dylib             	0x00007fff83822ffd _dispatch_mgr_invoke + 154
2   libSystem.B.dylib             	0x00007fff83822cd4 _dispatch_queue_invoke + 185
3   libSystem.B.dylib             	0x00007fff838227fe _dispatch_worker_thread2 + 252
4   libSystem.B.dylib             	0x00007fff83822128 _pthread_wqthread + 353
5   libSystem.B.dylib             	0x00007fff83821fc5 start_wqthread + 13
Thread 2:
2   libclient64.dylib             	0x000000010310d967 JNI_CreateJavaVM_Impl + 49160
3   libclient64.dylib             	0x000000010310d7cb JNI_CreateJavaVM_Impl + 48748
4   libclient64.dylib             	0x000000010310d72a JNI_CreateJavaVM_Impl + 48587
5   libclient64.dylib             	0x000000010310d303 JNI_CreateJavaVM_Impl + 47524
6   libclient64.dylib             	0x000000010310d1f4 JNI_CreateJavaVM_Impl + 47253
7   libclient64.dylib             	0x00000001031c2c5c JVM_Write + 1881
8   libclient64.dylib             	0x00000001031c27d7 JVM_Write + 724
9   ...ple.JavaApplicationLauncher	0x00000001a34a9c57 startJavaApplication + 3074
10  ...ple.JavaApplicationLauncher	0x00000001a34a9019 java_main_stub(void*) + 25
11  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
12  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 3:  Java: Exception Handler Thread
2   libSystem.B.dylib             	0x00007fff83884ea7 mach_msg_server + 468
3   libclient64.dylib             	0x000000010310e391 JNI_CreateJavaVM_Impl + 51762
4   libclient64.dylib             	0x000000010310e353 JNI_CreateJavaVM_Impl + 51700
5   libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
6   libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
7   libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 4:  Java: Gang worker#0 (Parallel GC Threads)
6   libclient64.dylib             	0x000000010310d275 JNI_CreateJavaVM_Impl + 47382
7   libclient64.dylib             	0x000000010312533c jio_vsnprintf + 310
8   libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
9   libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
10  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 5:  Java: Gang worker#1 (Parallel GC Threads)
Thread 6:  Java: Gang worker#2 (Parallel GC Threads)
Thread 7:  Java: Gang worker#3 (Parallel GC Threads)
Thread 8:  Java: Gang worker#4 (Parallel GC Threads)
Thread 9:  Java: Gang worker#5 (Parallel GC Threads)
Thread 10:  Java: Gang worker#6 (Parallel GC Threads)
Thread 11:  Java: Gang worker#7 (Parallel GC Threads)
Thread 12:  Java: Gang worker#0 (Parallel CMS Threads)
7   libclient64.dylib             	0x000000010350fc5d JVM_RaiseSignal + 924891
Thread 13:  Java: Gang worker#1 (Parallel CMS Threads)
Thread 14:  Java: Concurrent Mark-Sweep GC Thread
2   libclient64.dylib             	0x000000010310d9f9 JNI_CreateJavaVM_Impl + 49306
3   libclient64.dylib             	0x000000010312b446 jio_vsnprintf + 25152
4   libclient64.dylib             	0x000000010310d303 JNI_CreateJavaVM_Impl + 47524
5   libclient64.dylib             	0x000000010310d275 JNI_CreateJavaVM_Impl + 47382
6   libclient64.dylib             	0x00000001031c31f7 JVM_Write + 3316
7   libclient64.dylib             	0x00000001031c3181 JVM_Write + 3198
8   libclient64.dylib             	0x000000010312b2cf jio_vsnprintf + 24777
9   libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
10  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
11  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 15:  Java: VM Thread
6   libclient64.dylib             	0x000000010319dbbb JVM_Lseek + 176852
7   libclient64.dylib             	0x000000010319d90d JVM_Lseek + 176166
Thread 16:  Java: Reference Handler
4   libclient64.dylib             	0x00000001031aa175 JVM_MonitorWait + 3475
5   libclient64.dylib             	0x00000001031a96c2 JVM_MonitorWait + 736
6   libclient64.dylib             	0x00000001031a9495 JVM_MonitorWait + 179
7   libjvmlinkage.dylib           	0x0000000100095b9b JVM_MonitorWait + 59
8   ???                           	0x0000000106811cc8 0 + 4404092104
9   ???                           	0x000000010680685a 0 + 4404045914
10  ???                           	0x000000010680685a 0 + 4404045914
11  ???                           	0x0000000106801438 0 + 4404024376
12  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
13  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
14  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
15  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
16  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
17  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
18  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
19  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
20  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 17 Crashed:  Java: Finalizer
0   libGL.dylib                   	0x00007fff88ff3633 glIsList + 15
1   libjogl.jnilib                	0x0000000122c22e80 Java_com_sun_opengl_impl_GLImpl_glIsList__I + 27
2   ???                           	0x0000000106811cc8 0 + 4404092104
3   ???                           	0x0000000106806f5c 0 + 4404047708
4   ???                           	0x0000000106801438 0 + 4404024376
5   libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
6   libclient64.dylib             	0x000000010319eb7a JVM_Lseek + 180883
7   libclient64.dylib             	0x00000001031abdfe JVM_MonitorWait + 10780
8   libclient64.dylib             	0x0000000103288ba9 JVM_MonitorNotifyAll + 3717
9   libjava.jnilib                	0x0000000100488ac9 Java_java_lang_ref_Finalizer_invokeFinalizeMethod + 88
10  ???                           	0x0000000106811cc8 0 + 4404092104
11  ???                           	0x000000010680685a 0 + 4404045914
12  ???                           	0x000000010680685a 0 + 4404045914
13  ???                           	0x000000010680685a 0 + 4404045914
14  ???                           	0x0000000106801438 0 + 4404024376
15  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
16  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
17  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
18  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
19  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
20  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
21  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
22  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
23  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 18:  Java: Surrogate Locker Thread (CMS)
6   libclient64.dylib             	0x000000010310d1dc JNI_CreateJavaVM_Impl + 47229
7   libclient64.dylib             	0x00000001031bb57b JVM_IsPrimitiveClass + 4959
8   libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
9   libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
10  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
Thread 19:  Java: Signal Dispatcher
0   libSystem.B.dylib             	0x00007fff838082d6 semaphore_wait_trap + 10
1   libclient64.dylib             	0x00000001031bc123 JVM_IsPrimitiveClass + 7943
2   libclient64.dylib             	0x00000001031bbbf2 JVM_IsPrimitiveClass + 6614
3   libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
4   libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
Thread 20:  Java: CompilerThread0
7   libclient64.dylib             	0x00000001031c2de9 JVM_Write + 2278
8   libclient64.dylib             	0x00000001031bcebc JVM_IsPrimitiveClass + 11424
10  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
11  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
12  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
13  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 21:  Java: CompilerThread1
Thread 22:  Java: Low Memory Detector
7   libclient64.dylib             	0x00000001031be550 JVM_IsPrimitiveClass + 17204
Thread 23:  Java: VM Periodic Task Thread
4   libclient64.dylib             	0x00000001031c017e JVM_IsPrimitiveClass + 24418
Thread 24:  Java: AWT-Shutdown
11  ???                           	0x0000000106806d34 0 + 4404047156
12  ???                           	0x0000000106801438 0 + 4404024376
13  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
14  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
15  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
16  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
17  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
18  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
19  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
20  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
21  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 25:  Java: AWT-EventQueue-0
9   ???                           	0x00000001069d8f54 0 + 4405956436
Thread 26:  Java: Thread-3
3   libclient64.dylib             	0x000000010331674d JVM_ActiveProcessorCount + 969
4   libclient64.dylib             	0x0000000103316507 JVM_ActiveProcessorCount + 387
5   ???                           	0x0000000106811cc8 0 + 4404092104
6   ???                           	0x000000010680685a 0 + 4404045914
7   ???                           	0x000000010680685a 0 + 4404045914
8   ???                           	0x0000000106806d34 0 + 4404047156
9   ???                           	0x0000000106806e8d 0 + 4404047501
10  ???                           	0x0000000106801438 0 + 4404024376
11  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
12  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
13  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
14  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
15  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
16  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
17  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
18  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
19  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 27:  Java: Thread-4
Thread 28:  Java: Poller SunPKCS11-Darwin
3   libclient64.dylib             	0x00000001031c0398 JVM_IsPrimitiveClass + 24956
4   libclient64.dylib             	0x00000001032a9dee JVM_Sleep + 216
5   libjvmlinkage.dylib           	0x00000001000966ee JVM_Sleep + 62
6   ???                           	0x0000000106811cc8 0 + 4404092104
9   ???                           	0x0000000106801438 0 + 4404024376
10  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
11  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
12  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
13  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
14  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
15  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
16  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
17  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
18  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 29:  Java: Java2D Disposer
10  ???                           	0x00000001068069b3 0 + 4404046259
11  ???                           	0x00000001068069b3 0 + 4404046259
12  ???                           	0x0000000106806d34 0 + 4404047156
13  ???                           	0x0000000106801438 0 + 4404024376
14  libclient64.dylib             	0x000000010319eda7 JVM_Lseek + 181440
15  libclient64.dylib             	0x00000001031a8f84 JVM_StartThread + 2473
16  libclient64.dylib             	0x00000001031a8e7a JVM_StartThread + 2207
17  libclient64.dylib             	0x00000001031a8e1b JVM_StartThread + 2112
18  libclient64.dylib             	0x00000001031a8cbc JVM_StartThread + 1761
19  libclient64.dylib             	0x00000001031a8b2b JVM_StartThread + 1360
20  libclient64.dylib             	0x000000010310d0e1 JNI_CreateJavaVM_Impl + 46978
21  libSystem.B.dylib             	0x00007fff838414f6 _pthread_start + 331
22  libSystem.B.dylib             	0x00007fff838413a9 thread_start + 13
Thread 30:  Java: TimerQueue
10  ???                           	0x0000000106806d34 0 + 4404047156
Thread 17 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00000007fc026610  rcx: 0x0000000000000189  rdx: 0x0000000000000051
  rdi: 0x0000000000000051  rsi: 0x0000000000000051  rbp: 0x000000010e4003c0  rsp: 0x000000010e4003c0
   r8: 0x000000010492d880   r9: 0x00000000fffffffc  r10: 0x0000000106811c9b  r11: 0x00000001034e429b
  r12: 0x0000000000000000  r13: 0x00000007fc026610  r14: 0x000000010e400488  r15: 0x000000010513f000
  rip: 0x00007fff88ff3633  rfl: 0x0000000000010202  cr2: 0x0000000000000000
Does this happen often or only once in a while?
spell
Post by spell »
It's happened twice; once with the original release. I have not been able to duplicate it. If there is a way to collect enhanced log information, I will enable that for you.
From Christa:
  1. View->Reset View zoom (standard view not right)
  2. thickness should be selectable for all parts
  3. screw holes need more limiting (near eachother, edges, exclusion zones)
  4. Show PEM part number and allow change in properties & context
  • Origin Wrong on Ports
  • Unable to import pdc files from library
  • text can be placed that goes over the boundary
  • items that are over the boundary can not be deleted due to overlap
