ProtocaseDesigner.com
Custom Electronic Enclosure Design Software Forum
Skip to content
Running Protocase Designer with Administrator Privileges
Moderators: Colin, dronne, akirk
Postby dronne on Thu Mar 18, 2010 1:47 pm
Previous versions of protocase designer needed administrative privileges to run. Now, they are only needed to install. If you have to operate as a limited user on your computer, here are the steps:
[list]
[*]Download the latest version of Protocase Designer (released today, Thursday the 18th of March 2010)
[*]Right-Click and select Run As Administrator to install the program
Re: Running Protocase Designer without Administrator Privileges
Postby dronne on Wed Aug 02, 2017 1:37 pm
If you have no administrator access at all, then you can install protocase designer just for your user now.
When you install it, it will install to your Users\<username>\Protocase Designer 4\ folder. The only issue is that if you have already had Protocase Designer installed as an administrator, then double-clicking a protocase designer file on your computer will open with the old version. You should be able to override this by right-clicking on a Protocase Designer file and selecting open with... and going and finding the newly installed version that is in your Users\<username\Protocase Designer 4\ folder.
Return to Protocase Designer General Chat / Support
Who is online
Users browsing this forum: No registered users and 1 guest
cron
